One Less....
green73
One less ATR Strip Chip in use. I sent my chip out to Hood Tuned today for a reflash to the "Upgraded 2-Bar" specs. My Typhoon came with the Strip Chip, and I didn't want to have to run 100 octane. I don't know what that chip was supposed to do, and I only drove the truck about 20 miles on it. From what I am reading, since my truck is not highly modded I'll be better off with my choice. I can't wait to reinstall it and go...
green73
Re: One Less....
Is anyone here running the "Upgraded 2-bar" Hood Tuned flash?
What can I expect long term for mileage (Like I bought this thing for that)? Just something that is nice to know.
How is driveability?
I know power coming off the "Strip Chip" will be a less, but what can I expect there?
I am betting everyone's results will vary depending on location, and driving style. There has to be a baseline though.
Thanks
Fighting5thSVT
Re: One Less....
Thanks
Mileage? Who the hell cares...its a Typhoon!
Hood does good work:tup:
green73
Re: One Less....
Oh I am full on knowing the fuel mileage won't be all that great. I don't drive anything that gets what is currently concidered good mileage. 1973 Land Cruiser :)rotf: average), 1996 Land Cruiser (14-16 mpg average), and the kinda DD 2000 Dodge Ram Diesel (20-25 mpg average). Just one of those things that is neat gee-gaw info.
sytyguy
Moderated User
Re: One Less....
Mileage truly will vary, and be dependent on a myriad of other factors (from tire pressure to the health of your vacuum lines), but a healthy stock truck should (and this applies for almost all chips) see anywhere from 16-22 mpg. I personally average about 20 mpg in my Ty (with this same tune), but I live at sea level (16' below actually), have no elevation to contend with on my daily commute, zero traffic, and I drive at 60 mph.
But you can't get 2 identical 2011 GMC Sierras to get the same gas mileage in the hands of 2 different people, so you really will see different results from everyone else.....esp. given how different trucks can be, despite being "stock".
SY2455
70's Veteran
Re: One Less....
Just so you know, If I drive no more then 70 mph then I will get 25 mpg on the hwy as long as I use CC with mine.
green73
Re: One Less....
Thanks for the heads up Mr. Hood. Yeah I know it's one of those "Your Results May Vary" things. I'll be logging things and post up my results. Too bad I do not have a solid baseline to compare to though. I guess I'll add a few column to my fuel log, like tire pressure (check every few tanks), Octand filled up with, additive (if used), and fuel station used. Could be a fun, if long term involved, project.
sytyguy
Moderated User
Re: One Less....
Thanks for the heads up Mr. Hood. Yeah I know it's one of those "Your Results May Vary" things. I'll be logging things and post up my results. Too bad I do not have a solid baseline to compare to though. I guess I'll add a few column to my fuel log, like tire pressure (check every few tanks), Octane filled up with, additive (if used), and fuel station used. Could be a fun, if long term involved, project.
Observing fuel economy is a science in consistent repetition. If you get 18 mpg on one tank and 16 mpg on another, but drove different routes with different traffic, etc... then the results are extremely difficult to compare. Compare tanks where you drove in a similar manner over a similar route with similar traffic conditions.
But you're on the right path......the more variables you consider, the more you learn and the more your wallet can benefit.
