one piston ring?
bezerk
Hello
i bought i Ty after 2 years of searching, a ty with some probs that is.
the engine isn't running strong and is smoking like a MOFO, this could be caused by several thing ofcourse, so i started a compression test.
one piston-ring is really bad (checked with oil above piston so no leaking there and is was goood).
allt he others are maximum
So my question is: can i screw of the carter-pan and take the whole thing down from under? i really hope so.(don't know the wright translation but i geuss you know what i mean)
another question.
when driving i hear several cracks in the drivetrain, i have the feeling that in coners the front and rear tires are sqeeuking beacause of the differatial isn't working, did annybody had that problem before??
Rene
Lynn D. Brown
New TY
New TY
Rene,
I don't think the Oil Pan will drop w the Front Differential in there. Then if U try to get just one piston out, U will have to remove the cylinder heads and everything above them in order to push out the piston.
I'm not sure whether U can drop the Crank and get the piston out the bottom because of the 1-piece Rear Main seal, which is bolted to the back of the block above the crank.
A shop would pull probably pull your engine to do all this.
On your Front end problems, U need to diagnose the problem to narrow down the possibilities, which R endless. The 1st thing I would do is check the steering linkage for play by jacking up the wheel and shaking it side to side, and then observing the linkage connection points for play. Then U can check the ball joints by shaking the wheels from top to bottom. The noise may also be loose Torsion Bars.
bezerk
That isn't a happy Massage.
How long does it take to take the engine out?
and is it an easy job, i have pulled quite a few engines, but never a engine wich has such a full engine room :-?
anny other suggestions when i completly pull the engine out doing other stuff when an engine has 95K?
Rene
syclone2910
I had my engine out in 5 or so hours. If you are going to pull the engine out of it you might as well do a good rebuild on like new pistons, rings, rods, breaing and stuff like that so you dont have to do it all over again. Hell I had a bent rod and nver new it! So check things out.
