One smokin turbo!!
socalblue
Had idle issues taken care of now, (not fully plugged in O2 connector will f up your tune) hence why its in the tuning forum...but now I have a turbo problem. :(
I noticed smoke coming from the turbo not good...not a lot but noticeable. Common causes by doing my homework shows that its restricted oil passages/hi oil pressure. Well I checked my oil feed line, made sure oil would come out before the turbo, yes it did and forgot to hook it back up causing a oil spill, not pretty oil return line is also okay.
Would appreciate any help, don't wanna run her with smoke coming out the turbo!! :tdown:
berzerker
wookie
Re: One smokin turbo!!
how's the pvc system . everything hooked up or ? mods to the intake system ? breather system on valve covers good.
socalblue
the pvc valves work when i blow into it it opens up...as for air intake I took off air filter and ran it without filter to see if thats the prob...still was smoking...doesnt start smokin till it starts nearing 180F.
Also checked for the 3rd time oil return and feed line to the turbo...flows good.
could that fact that the ty sat for a few months be the cause of the turbo problem like the oil gunked up or something along the turbo bearing? there isnt any blue smoke from the exhaust however? dunno anymore!!!!!! :rant:
socalblue
How Do I Check To See If It Is A Clogged Cat? Ive Read On Here That You're Supposed To Take Out The O2 Sensor And Let It Run But Wouldnt That Make The Car Run Crappy Or Does It Not Matter Youre Just Looking For Pressure Being Released From The O2? Ive Also Heard Of Disconnecting The Downpipe? Are These Things Okay To Do To Test For A Clogged Cat?
socalblue
WELL I NOTICED JUST TODAY THAT MY FUEL EVAP LINE WAS BROKEN OFF RIGHT BY THE THROTTLE BODY, DON'T THINK THAT COULD CAUSE MY TURBO TO SMOKE BUT...JUST ANOTHER THING TO FIX I GUESS!! THIS TY IS REALLY PISSING ME OFF :rant:
