sharkbait
im gonna try to make this a simple post. especially since i have so many things influenced my decisions.
i have a 95ext RWD 4.3 TBI 4L60e S10
i have a syty motor totaly complete. harness, fuse box, excessories etc.
i think im gonna put the syty manifolds/turbo on the 95 motor.
i will then need to buy a larger (V8) injector, afpr, bigger fuel pump, msd btm, and i will monitor the motor with a wide band.
PROS
then i can keep my 4L60e that is rebuilt/with a shift kit and my 2800stall converter. i wont have any issues with the tranny shifting, i can leave the column shifter alone. don't have to buy a floor shifter (pricy) i don't have to take out the motor. and thats important because i can't lay the truck up for more than 3 or 4 days.
CONS
if i put the syty motor in with the harness. im going to need a early model 700r4/4L60, then have it rebuild just to play it safe. and like i said, id have to lay the truck up which really isn't an option this summer.
so to you none factory syty guys..... what do you think? how easy/hard should it be to put the manifolds/turbo on the TBI 4.3? should i :hang: i used to be on a forum astrosafari.com, and there was a guy that did a CPI 4.3 astro. he did a similar turbo system. he didn't have any really concerns up to 12 or 13ish psi on 94 octane.
i will definetley put the real syty motor in with the complete harness. i would love to do a 4L80e or even a th400. i just cant lay the truck up this summer.
any ideas would help.............but please don't suggest i buy a syty :chair:
PROS
CONS
