Orange electrodes
4C FED
Absolutum Dominium
I pulled the plugs tonight to take a look see out of curiosity and this is what I found:
All the plugs look the same. I think there is around 3k miles on these.
I always run 100 octane unless I'm low & then I'll put 10 gal's in to get me to the race fuel.
I've run about 1 can of Seafoam (1/2 can/tankful, spread between several tanks) through the fuel system since these were installed.
Of all of the previous plug changes (UR5's & UR5ix's), none of the plugs looked like this before.
Are the UR6's too cold? Result oof the Seafoam or the 100 octane gas?
I installed new UR5's since I'm going to try & get this SMOG'ed on Friday.
It runs much better now with the new plugs.
Loeryder
Re: Orange electrodes
I think you are supposed to change plugs after running a heavy intake cleaner like that.
I would attribute it to the seafoam and try a new set.
kentuc
Nothing to worry about. It looks like the dye they use in certain brands of gas or additive.
4C FED
Absolutum Dominium
Great & thanks.
Stock chip installed, new plugs, 195 t-stat, fresh oil change, new cap & rotor, install stock FPR, IC pump disconnected & some 87 octane.
Wish me luck. I'm off to see the SMOG Nazi's tomorrow.
