original boost solenoid
sygirl#1763
Recently I bought a PTE51 but do I leave the original boost control solenoid (from the stock turbo) into the computer ?
How can I send a datamaster file and who can read it ?
How to avoid high KPa into the intake manifold ?
Thanks,
Angela
ghettosled
SYTY SUPERSTORE
yes you can splice the selenoid into the blue vacuum hose if its a PTE turbo. You can avoid high KPA by losening the wg rod.
kwick6
Just disconnect the stock solenoid and use the boostvalve to control boost for now. With the open exhaust you have, you'll get boost spikes if you don't use the boost valve. You'll need to have custom tuning done before you can use the stock solenoid to control the boost accurately.
Use datamaster often while your getting your new setup installed and the boost set. I'd recommend using some race gas while you make the adjustments in case of any boost spikes, you'll be safe.
