Ostich cannot connect to ALDL
epix
Typhoon
Just installed my wideband today (PLX SM-AFR) and installed Ostrich with Tuner Pro RT as well.
I downloaded the code 59 bins, xdf, and ads files, yet still Tuner Pro will not connect to ALDL. I have tried using both a serial aldl cable, and a usb aldl cable, as well as using different usb ports.
What is causing Tuner Pro not to be able to connect?
MRKING
New Parts for Old Trucks
Re: Ostich cannot connect to ALDL
Did you hit f4 and load the .ads file in tunerpro after selecting the .xdf (Control e) ?
12secondSY
Syty Killer :(
MRKING said:
Did you hit f4 and load the .ads file in tunerpro ) ?
Thats the one I was talking about yesterday when we talked. I knew it started with an "a". :rotf:
epix
Typhoon
tried that.. still wouldn't connect
Also with every bin I tried (mainly 50# and a 40 and 60# bin) the truck would idle 1500 rpm but run very lean with the throttle not being pushed much while driving.. almost would want to stall but would not.
I'll keep researching as much as I can and figure this out, just ordered some 75lb injectors from RPM anyways
WyoSyclone
Hi Epix,
Using 4.14 TunerProRT? Get that if not.
Go on to the TTS sight and look at the Datamaster documentation for latency settings on your USB port.
In TunerPro, click on the serial cable-looking icon "auto detect attahed hardware". Click on the microchip looking icon "enable/disable emulation".
With Ostrich you can't datalog via ALDL.... Prominator you can.
Key on first before launching TunerPro?
epix
Typhoon
WyoSyclone said:
Hi Epix,
Running 4.14, I use to be able to connect to ALDL with datamaster before using the Ostrich, but now cannot in either tunerpro or datamaster
Heres what I been doing.. open the code 59 bin, xdf, and ads file, upload bin to ostrich via tuner pro, click verify, then turn on emulation (everything says its A-OK) but truck runs poor. I have also tried turning on emulation before uploading the bin, same results
I have always been opening TunerPro before turning the key.. but I have hit the 'connect ALDL' button while the key was on and still does not connect
What ALDL cable do you have? Moates? If so watch the switch position.
I just caught a local wanna be tuners that were fighting tuning while in ALDL mode since the Moates cable will let you force it into ALDL mode, it will cause the idle to raise up.
WyoSyclone
Almost sounds like a USB port problem. I don't have my laptop here. Go to the TTS sight and read their documentation about setting the latency settings on the USB port. Also, the latest TunerProRT requires, I think, a different baud setting. I think they have that notice on the front page of that website. Are you always plugging into the same USB port?
UR50SLO
V6+2=LSXCamaro
Just had Jeff help me with this problem on Dave Alwine's truck this morning.
We were just trying to get Tuner Pro to read the ALDL stream to get some info.
The port configuration was the problem. Jeff said to configure it to COM 4 or under. *usb*
We had to download a older .asd file to work with his code 58 and 3bar but it ended up working fine.
I'll bet if you plugged your stuff into my laptop that's already up and running on COM2 with Tuner Pro
it'd work sweet just like it does in my wife's Ty.
COM/Port settings first. IM me tonight.. I'll help ya get it setup.
BTW.... You can't use your stock ECM with 75#/HRS!!!!!! I've got a modded ECM for that injector.
~Scott
