Ostrich Question
Ok so when I get a new motor in my ty i want to save up and get a moates ostrich so that I can code59 tune the new motor so it doesnt blow up...
I do not have a stock chip in my truck... my question is...in order for the ostrich to work.. do i absolutely need the OEM chip to piggy back the ostrich off of?
MRKING
New Parts for Old Trucks
Re: Ostrich Question
youll need a g1 or g3 adapter board and the stock chip must plug into that .then the ostrich plugs into the adapter board to emulate the bin file
Poconojoe
Jusy plug the Memcal you're using now in to the adapter. It doesn't need to be a stock one, but does need to be for a St or Ty
sy#2921
BAMF
You just need a stock style memcal. It doesnt need the stock programming on it though. The adaptor is piggy-backing the other part of the memcal not using the prom chip that is on there
oh ok i get it now.. is there a program that I should run first to check and see if everythings working correctly? The truck is getting a new motor put in it thats for the most part completely bone stock with harder parts (if i ever get it :squint:)
