over boost
syclonekid43
i checked my timing the other day and it was off a bit now its set at 0 de. once i a while not all the time it seems to over boost and it feels like the motor hits a dead spot i let off the gas and get back on it its ok again i kept eyes on my boost gauge (autometer) and it went up to about 20 psi of boost i checked all the vas lines i looked at the timing again i cant seem to find the problem does anybody out there have a clue on what this could be
Re: over boost
Did you do a TDC check with a piston stop, to make sure your balancer hasn't slipped?
ghettosled
SYTY SUPERSTORE
you'll never know whats happening without a scan tool. Make sure you have a cat and check your a/f ratio. You might want to try fattening it up, and lengthening your wg rod.
20psi on pump gas is a recipe for disaster. if you have a KB chip its probably too late.
do yourself and get some hard data via diacom, datamaster, snap on whatever.....
syclonekid43
i have a snap on scan tool but i dont have a data cable for it. im running the stock chip in it which when i got the truck it had a hypertech in there and thats why i blew that motor. im not sure if the pump is a factory one in there i never droppped the tank on it. what should i look for on the scan tool.my next step is to get an electronic fuel press. gauge for it do you know about how long the w/g rod should be from gm.
