Over boosting
Al's Clone
Im a fairly new owner of a Syclone, Its basicly stock with the exception of a chip, 3 inc exhaust and no cat. Im experiencing boost of up to 20lbs . Im considering putting on a cat to solve the problem. Could anyone reccomend a good cat?
wheels
Re: Over boosting
if you dont have a cat, that would cause overboosting.
SeattleSy#1255
Category 5 Conservative
Re: Over boosting
external WG and a good boost valve will solve the problem...
your problem is likely due to the stock WG being undersized, with the cat off it doesn't have enough back pressure.
Al's Clone
Re: Over boosting
Thanks for the advice, wouldn't a external wastegate be more expensive. If i used an external wastgate wouldn't i also need a new down pipe? I appreciate any advise
