myclone
Been mulling over the ellimination of the over boost feature on the ultimate idea I had.
I think I ran into what Id call a minor snag in my idea...
Lemme guess... If I got rid of the above feature I still cant run higher boost due to there not being fuel/timing maps for proper fueling above the boost setting on the ultimate.. So... if I say, wanna run 22psi on the Tx-15 setting after 15psi there is no fueling/timing maps for the ECM to keep adding fuel/timing/KR/etc???
What I was wanting to do is run low timing and high boost. I was thinking of getting rid of the over boost feature and just using the timing/fueling map but running whatever boost I wanted to.
Aint gonna work is it?? Didnt think so... Dammit!!!
FWIW.. ECM has no control of boost on my truck. WG is a external thats controlled by other means. I just use the ECM for timing/fueling.
TIA...
TIA...
