graham1524
Well-known member
I started trying to figure out my Tunerpro log and at 3325 RPM I have 125.93 KPA (wich converts to 18+ PSI?). I'd have to say thats overboost and what should I do/check
In TunerPro, 100kpa equals 1 bar, or atmospheric... so, you're not into boost till you get past 100kpa..... in the monitor section turn on kpa and turbo boost at the same time while you play back a log... you will see how they relate to one another... you're actually at about 5psi of boost.
hope this helps....
