BoostedSUV
Been having some problems with my truck getting hot while driving. Just put the truck together and have about 500 or so miles on the build. The engine, radiator and electric fan came right out of my old truck and went into the new one. The only thing I changed was I put an Edlebrock aluminum water pump in that I bought from V6Quick and some under drive pulleys. I changed thermostat twice to be sure it wasn't something simple and the elec fan kicks on at 180* (even tried with the fan coming on with ignition)
I let the truck idle with the radiator cap off and I don't see very much coolant flow, even after the thermostat opens. Even if I bring the RPMs up the coolant level will drop about an inch but there still isn't good flow of coolant. The upper radiator hose gets hot and I can feel the pressure in it but the lower is warmer and squishy and it feels like the driver side of the rad is hotter than the pass. The truck will idle in park and stay at around 180* but when I'm driving in traffic, sitting at stop lights in Drive it will start climbing over 220* the water pump was brand new and the rad came out of my old truck and I didn't have this problem :dunno:
I guess what I'm asking do you guys think the radiator is plugged up or the water pump isn't flowing? Any better ways to confirm before I start throwing parts at it?
