P-->Gear table...stalling sometimes
TYTILIDIE
METH HEAD
Ive messed around with the p to gear table a little and cant figure out how to get it to stay running during the transition. Any help out htere on this? I have my AFR's dead on in Park, Neutral and Drive. But when swithing form Park to Drive, its dies.
turbodig
Re: P-->Gear table...stalling sometimes
My bet is that you have a fueling issue at low RPM, higher MAP. There's typically a load spike when you change states, and it's a part of the fuel map that doesn't get normally seen.
Timing in the same MAP areas also makes a difference.
This isn't really something you can tune well in the truck (not sure if you are)... gotta take some data, go back inside, read the data, figure out what it means, work up a new bin, test, repeat.
Too many people are trying to do it in the truck with the laptop on the passenger seat, and you're never gonna learn anything that way. There are too many variables to watch to be able to do a good job.
My .02
SBNova
I would also suspect timing. You say the AFR is good, what is it? I have the VE #'s higher at the lowest VE cells in the idle area, as a stall saver if you will while still achieving my desired AFR at idle. I command about a 14.7 AFR at idle in nuetral, a 14.5 in gear, and a 14.3 with the AC on in gear. (those three variables end up in different VE cells in my application) I didnt want the engine to run as lean (or hot) in gear with the AC on vs nuetral. I have heard alot of people say they desire a richer idle, but mine idles great like this. My idle timing is typically 16-18 degrees at these AFR's.
Also make sure your engine is at operating temp when your tuning, or other tables become involved. There are cold start and run tables, if this is where your problem lies.
I am with dig on this, is a VE section you don't normally see and will require some careful watching.
TYTILIDIE
METH HEAD
I understand everything except for going back in to do it. Is it because I dont kow whcih table to use wile its running? Not sure why it owuld be better on a spreadsheet. A cruise run or 1/4 mile run I could see. I do try to tune while Im driving or Ill stop and make some changes then drive again. So far its seemed to benefit me for the most part except for things like this. Where I would be lost is, even if I did it on a spread sheet, how would I know what table to change and what to change on it? I ve gotten the hang of seeing first hand whats affecting what while the truck is running. Ill try it though, listen to the pro's.
turbodig
Well regarding idle at least, you're looking at 6-7 things:
Coolant temp
Timing
RPM
MAP
IAT
IACPOS
AFR
TPS
If you can watch, and relate, all of those in real time, while changing things in TP, I'm betting there's a job for you at Los Alamos. :)
The problem is, on a cold start, all of them are moving at the same time, and any of them can affect what your WB reads for AFR.
I export the whole thing (the duration of the idle log that I'm looking at) into Excel. Then I can sort by RPM and MAP. (giving me a single VE table cell) From there, you look at the differences in fuel/timing between the frames that are in the same VE table cell. Your reported VE value isn't changing among these frames, so how can AFR change? Airtemp, and timing. (possibly delta TPS too, but we're getting ahead of ourselves)
Once you stop to take the time to look at what's happening in your problem areas, you'll spend less time chasing the correct fueling around.
