Pad Replace/ABS Code 62/Pedal to the Floor
jdeangelis
I had the front brake pads replaced about 3 weeks ago. I left the station and it felt like I had new brakes. High pedal and solid stops. About a week ago stated to notice brakes losing strenght. I figured it was my rear brakes that I had been told needed to be replaced. Yesterday brake pedal went to the floor and ABS & BRAKE lights popped up. Checked the codes: 62. Went through the test procedure and wound up with: replace EHCU.
I assume this means that the ABS unit needs to be replaced? Does anybody feel that having the brakes replaced caused this problem? It would appear from the archives that if the bleeder valve wasn't open whent he caliper was depressed, that sediment most likely got into the EHCU.
Odd thing is brakes still function, just not that well.
Any help?
Thanks,
Justin D
92 TY
InvisiBill
Some people have fixed recurring ABS codes and other problems by flushing a lot of fluid down through the system. Basically just keep bleeding out at the wheels, and adding more fluid up top. Not the easiest thing to do, but it's a lot cheaper than the ABS unit... Probably at least worth a try.
manitoufs
Did the mechanic crack the bleeder valves to allow old fluid to escape at the caliper while he pushed the pistons back into the caliper bodies? If he didn't, he may have forced the old, crudy fluid back through the ABS module filters. This is a major no-no. RTFM (Read the fuckin' manual)
A lot of mechanics don't know this. It can mean death for the unit.
