I sent my manifolds to "MOORE COATINGS".com and had them use their 2000 degree coatings. The color is a flat grey/blk. It will not rust through or change characteristics with heat cycles either. They also do turbine housings too. He generally bids the job higher than he actually charges just to be on the safe side.
Now these were turbo manifolds for my Nissan L-6, which gets way hotter than my SY manni's.
Hope this helps................Vincent :tup:
Ceramic coating... specifically Swain is your best bet for heat retention and durability. If you're going to paint them, use a high quality, high temp paint.. ie VHT 1500 degree, or BBQ paint. Only one's I've had luck with lasting longer than 45min - 1hr. Just my 2 cents.
