pan bolts snapped off?
QWK STRM
1889 92Ty
So my Ty had 3 bolts on the trans snap off while upgrading the pan. There is no rust at all and all the other bolts came out nice. I tried heat with penitating oil still no good. The 3 that broke go through at least I drilled one and tried a easy out they are so stuck the easy out broke great those are fun to be drilled. Is there such thing as a easy in maybe I could thread then through? Any ideas? Thanks
12secondSY
Syty Killer :(
Re: pan bolts snapped off?
There are mobile services that can come to you just for situations like that. They can get it out in about 2 minutes. Might not be cheap but cheaper than a trans if the case gets damaged.
If it were me I'd weld a nut to them. But I don't know if you have a welder. I've also drilled going progessively bigger until I can clean the threads with a pick or a tap but you have to be perfect on the first drill you do with that.
QWK STRM
1889 92Ty
Thanks that's what I was thinking too I started small drill bit as well. But the one with the easy out is going to be hard. I should be more than capable doing this as I am a aircraft mechanic and deal with this suff often. But idk y these bolts are so stuck its a mystery.
Captain Morgan
Moderated User
center punch, drill, extract, worst case scenario is you toss a heli-coil in, not the end of the world
Syclone22
I hope you get this fixed soon these trucks are
older then 20 years so many parts will need replacing ..
QWK STRM
1889 92Ty
They are flush with the trans and no welder. Looks like I will be using the right stuff gasket maker the get to way.
QWK STRM
1889 92Ty
Guess the right stuff will seal it till the trans needs a rebuild. Its only 3 out of 16.
QWK STRM
1889 92Ty
I did drill them got one drilled out saved some threads but the 2 with easy out stuck in them are no good. I did drill with lh bits I think they were over tightened and have the treads stuck in the bolts. Well rtv is on the 2 and no leaks yet this will be a fix when I blow the trans someday.
