Slyclone
Well-known member
Couple misc. Items I have from old truck stuff laying around maybe some one could use something.
Typhoon rear brake shoes. Unknown brand. Came with typhoon.
Used OEM heat exchanger hose dated 081991 KVL(long hose)
2 used lower intercooler/exchanger hoses. 1 dated 0892 from my 1992 typhoon. Other can't read. Little L shaped 90 degree hoses on lower exchanger
sheet metal gauge pod. Has 3 spots for 2 1/16 pods. Goes where radio is. Came with syclone when I bought it.
3 Allen head bolts for wheel center caps NOT OE. Came on my typhoon. Switch to original. Sold truck.
3 A/C bolts ( with flat spots )
Coil/ICM wire (red/white)
Alternator/waterpump support bar
OEM 700r4 shifter bracket
lightly used Accel ICM PN 35362
Standard ICM used. Back up part in box.
Beat Dist. Pole ( rounded out cap screw ) has good coil, factory distrinutor gear.
1 bent front turbo Wheel
used fan blade ( tossed the clutch was leaky )
OEM coolant overflow tank (with hose barb)
Jabsco circulation pump (12v dc 59500-0012) Have plug.
OEM horn
OEM oil cooler bracket (inner driver fender )
OEM Washer pump bracket
March perrformance billet alternator pulley, have the billet face for it too.
spare gmc typhoon alternator
spare gmc typhoon starter. Needs solenoid.
New MOOG problem solver pitman arm
"my other truck is a busted typhoon" sticker 1 frost white/argent typhoon, 1 aspen blue/argent typhoon
1 NOS GMC black "C" letter (last one on earth)
NEW 1992 GMC truck brochure ( features syclone, sonoma gt)
1 broken typhoon key ring ( small enameled typhoon keyring was on leather piece, wore out.
OEM horn
