PCV setup and Vortecs
NOWAY55
Can someone set me straight on the use of a PCV system with Vortecs?
I am wondering if having the PCV setup to factory specs is causing an issue. Do I just need breathers or what is recommended? What are the possible problemw with having the factory PCV's on?
4C FED
Absolutum Dominium
Re: PCV setup and Vortecs
The common problem is oil in the intake tract where the PCV's feed into.
NOWAY55
So, what do you recommend? Should I just put a breather on both covers and be done with it blocking off all other vacuum hoses?
I do have a lot of oil being sucked into the intake. My A-A IC is dripping with oil.
Also getting a lot of part light throttle KR and very little at WOT.
I am thinking it's the PCV system screwing me up.
MRKING
New Parts for Old Trucks
You may have another issue if that much oil is being spit out . Either your pcv setup takes the oil or it all drips out of the breathers onto your motor, its up to you .
Do you have a wide band 02 hooked up to see why your getting the low rpm kr ?
