Re: pcv ?
you would have either one or 2 bungs welded into the exhaust pipe or maybe even into the header or crossover, a fitting in the bung(s) and then the breathers in the valve covers with hose running to the fitting with check valve(s) in the exhaust point of your choice. that way your pressure is sent straight into the exhaust just like the dragsters.
would probably be best to put it into the down pipe so you are not coating the inside of the turbo and crossovers with oil with blowby.
we had a dragster in the shop last week and i was looking at it, so my memory is fresh.
although dragsters have no exhaust it just dumps out of the headers, so if you have alot of blowby you might be coating the exhuast with oil, which if you were running a cat could clog it or the muffler up after time, but maybe not.
just a thought.
been also trying to decide what to do with my pcv's, i might try this.
