Phil Long is da man
juicehead9
93 Typhoon # 0973
Re: Phil Long is da man
Now if I could get up to Phil in winston salem NC to get him help me tune the TY I would be set... O wait I need to get a Gilbert propshaft to drive the thing!!!
MAITAI1993
DON'T MAKE ME SLAP YOU.
sytyguy said:
YES lots of time and stress so much I almost sold the truck... good thing I did not because now its what I thought it should be I got a chip from Phil (not baggin on Phil he is a good guy) but when it came down to it not running right ME = BACK BURNER I got the #50 chip and injectors and put them in at the same time my truck would not start so I called and they told me the chip was in wrong so I checked again and it was not so I called again the first chip he sent was not burned so I got another one .And the truck started up and ran drove it home and got on it a few times got home turned it off and it would not start back up it would start and die. so i now had to wait a bit after driving it long distance to start it back up (when it got a bit colder) so I went back and forth for a while (this is wrong thats wrong dont use alky ECT) so I put my stock INJ. and chip back in and no start problem truck was not as sluggish yada yada yada.. so I put the #50s and chip back in went to turbo thunder and ran a 14.0 and then ran a 13.7 stock is better then that with all the money and time it should be better then stock...BULLSH-T !!!!!
WASTE OF MY TIME AND MY MONEY....
but look on the bright side its fast as shit now and with a bit more tuning it still can be faster..
This is in no way a bash....but I do belive that you cannot tune a car without being in it...
and I hope this does not cause any shit storm... :(
QUICK STORM
B.A.M.F. BMW Tech
so did you just take the chip out and mess with the fuel tables on the stock ecm, reason i ask is cuz my ecm is moddded for 75#s and i have his 75#chip
MAITAI1993
stock ECM was his chip :( but now its a Jeff Scott (JSMANUFACTURING) :D :tup: and has not been better at this point I could not be happier and Jeff says there is another full second left in my truck if he had more time to tune (was only in town for a few days) we shall see..
