Photoshopped picture?
BoostedSUV
Re: Photoshopped picture?
Looking great Matt! Glad to see some progress on this thing since the last time I saw it sitting all lonely and neglected at the wrench session.
mattw
Front section of frame re-sandblasted:
Then primed with self-etching-primer:
Once it gets painted black it will finally be time to start putting everything back together.. :)
mattw
So what do you do when you want your fasteners to look nice but you are too cheap to buy new??
Step 1 - Sandblast:
Step 2 - Powder Coat:
Step 3 - Install:
Firewall and frame are finally all painted.. Time to start putting everything together..
BigBadSmoosh
you were probably thinking about stealing all of his powder coated bolts..
BigBadSmoosh
not a fan of the black/silver.. but do whatever makes you happy =
steering setup looks sweet..
mattw
I don't like it either in the pics. The flash makes the silver look really bright but its actually a dark silver. I tried taking pics with the flash off but they come out too dark. Its hard to get good pics in that building. It looks pretty sick in person..
4" exhaust(with 3.5" electric cutout, cat,and muffler) stem to stern:
Electric Cutout:
That nasty looking trans and transfer case are temporary. I'll run them this summer but most likely next winter it will get the 80e and AWD case which will be cleaned up nicely prior to install...
mattw
I got some new parts:
My favorite plug wires:
The parts needed to run -8 braided line from the filter up to the rail:
Metal bearings to replace the junk rubber bushings that came with my QA1s:
It looks like I will get all day Thursday to work on my truck and my brother-in-law is going to help out. I'm thinking we will get the front suspension all together and get the engine in..
ziembic
That four inch exhaust looks killer. Looks like it was stock. It is amazing the progress one can make with the right tools, parts and brains.
mattw
Thanks! That was the goal was to follow the routing of the stock system and try to keep the 4" pipe far enough away from everything.. The shock boot gets really close to the pipe when the suspension is fully extended but it seems OK at normal ride height. I think everything else has plenty of distance from the pipe. I reused the stock hangers and the stock cat bracket and shields... Thats part of what makes it look so factory. I just hope its not too loud for highway cruising... I searched and searched for a larger 4" muffler that would fit under there and couldn't really find anything...
ziembic
That looks like a magnaflow muffler, if it is they sound good but not too loud. For reference, this is on a N/A big block, I haven't heard them on anything else.
mattw
The muffler is a Magnaflow.. Good eyes!
We didn't get quite as far as I hoped but here is the update:
Installed new rear pinion seal and driveshaft:
Ditched the junk rubber bushings and installed the metal ones in the QA1s:
Installed front suspension:
Made brackets to bolt to the back of the engine. These will be used to attach a chain to when installing/pulling the engine.. I'll also use them to bolt ground wires to..
mattw
Brackets finished and installed:
Locking clips installed on exhaust manifold bolts:
Cut gasket for and installed MAP sensor plate:
NGK TR6 plugs installed with new Taylor wires:
Dropped engine in truck:
Cut and re-glassed AC cover so that it clears the valve cover:
It looks happy in there... :)
sypwrdss
Here is my old 94 Syclone Pwrd Bravada. It was so much fun, miss it dearly. Sold it to a guy in Indianapolis, Indiana back in 2008. I shaved the roof, rear door handles and tailgate. Was looking for some SY wheels but sold it before I got that far.
mattw
That would have looked really cool lowered with some sy/ty rims.. I have a set of sy/ty rims for mine. I'll probably put them on after I get the cladding done..
mattw
Some progress was made today. I'm at the point where there are a ton of little things to do that take more time than they should..
-Put the wiring harness in the truck and made some heat shields for where the wires go though the firewall to the ECM.
-Hooked up the -8an braided fuel line to the rail and ran it down the top of the tranny.
-Figured out how I am going to plumb the power steering pump to the Hydroboost then to the rack and pinion unit. Had 1 line made up at NAPA. Need to have 1 more line made and that will be done.
-Worked on the AC cover. I may be able to sand it and spray it now or it may still need 1 more coat of bondo..
To Do List:
Finish AC Cover ----- Done
Build heat shield for AC cover
Finish heat shield near ECM wires ---- Done
Build heat shield where crossover is near rack and pinion neck
Finish wiring harness ----- 90%
Build MAP sensor bracket ----- Done
Build Coil Bracket ----- Done
Build throttle cable bracket ----- Done
Finish running fuel lines and install new filter ----- Done
Install sending unit and electronics for Fuel Pressure Gauge ----- Done
Install front brake line, fill, and bleed ----- 50%
Build injector wiring harness ----- Done
Connect boost gauge
Finish bolting tranny to engine ----- Done
Bolt torque converter to flex plate ----- Done
Install radiator support, radiator, and fans ----- Done
Install tranny cooler and connect lines ----- Done
Finish building thermostat neck ----- Done
Build intake air plumbing
Install fenders
Modify and install fenderwells
Install hood
Install Grill
Install bumper
Purchase and install Wide Band 02 sensor and electronics ----- Done
Replace Heater Core
There is more.. But that's all I can think of at the moment...
