Photoshopped picture?
mattw
Re: Photoshopped picture?
Curious....how did you check the wg spring rate? I need to check what spring mine is and hadn't thought about it long enough to figure out a way to check it
I just put a regulator on an air hose and kept increasing pressure until the wastegate opened. My regulator has a gauge on it so I just watched to see what pressure it took to crack the valve..
nastety92
I would also suggest checking this spring ever year. If you are like me and don't drive the truck in the winter I've had the spring rust up. I've had numerous spring replaced in my Racegate.
Good luck, looks great.
Nick
mattw
What caused the broken rod? Bummer! Looks good now though!
Too much boost + no tune = boom... :(
Nick
Thanks.. I'll be sure to do that.. This winter I plan to swap in the 80e and AWD case so it will definitely be sitting for a few months..
mattw
OK, no lectures about my driving with my little girl in the car.... I didn't mean to kick it out like that at the end...
I am still taking it kinda easy. I'm but no means flooring it and I am kinda afraid to(don't want to blow it up again...) I'm not seeing any knock, my fuel is rich(for the most part) and my timing is mild...
mattw
So Renz gave me his old intercooler. Its not as big as the one that I wanted to run but it will certainly do for now..
mattw
sexy pic.
are you gonna trim that chin spoiler at all to allow a little more flow? or put a scoop on the ic?
Thanks! I'm not sure yet.. The next time I go to my parents I am going to see what I have laying around as far as those plastic spoilers go.. I def want to do something to increase airflow.
The truck likes this intercooler BTW.. I can push 14lbs of boost with no knock... :) My MAT is way lower now with the intercooler. They would go just over 150 without an IC. Now they stay nice and cool..
mattw
Not very economical at 1.2 mpg...Jim
Here you go:
I am actually kinda curious what kind of mileage I will get with this.. Once I get the bugs worked out I'll have to try really hard to take it easy on it for a tank and see what kind of mileage it gets..
IRVIN COLON
looks great, question what car or truck uses that rack and pinion seems to fits perfecly maybe some modification but great job leet me know thanks.
blackty
Ok. I was just being a smart-ass. Since I can't offer technical advice, that's all I have. Looking great...Jim
mattw
It came out of a 99 Explorer. I had to do some pretty significant cutting/welding/fabricating to fit it in there..
mattw
So I was having a pretty good day yesterday.. I took the family down to the park for my son's soccer practice in my car.. They loved it.. The kids like boost just as much as I do.. My wife even admitted it was fun..
One of the other dads heard me pulling in and asked what I had in there.. When I showed him he about fell on the ground. He used to have a V8 S10 and he was just speechless with what he saw..
So on the the home I was having more fun than I should. I've been fighting with my wastegate and I knew it wasn't properly controlling boost but I got on it anyway... POP - knock - knock - knock..
It sounds almost exactly like it did last time with the bent rod..
So, needless to say, I am getting a good brand 50mm gate and installing that for this go round.. I'm also going to return the gate into the downpipe about a foot further down.. Everyone says this helps with scavenging and provides better boost control..
I'll probably also port the wastegate housing of the turbo and open that up as much as possible...
I was thinking of maybe not using the wastegate port of the turbo at all and just plumbing my new gate to my manifolds after they combine but just before the turbo... It would allow me to use much larger piping to the wastegate but would be a fair amount of work. I'm not sure if it would be worth it or not..
So, hopefully with Jeff's old rods + stock syty pistons + proper boost control it will stay together this go round..
It was pulling really nice before I blew it up..
It tows really nice behind that big clunker of a Ford so maybe if I can get it to stay together I'll drag it to a meet this fall..
MikeRenz
not stock
He did this just so I couldn't ride in it. I specifically told him to not break it before Friday. That was Wednesday. Then he hours and does this...so selfish.
I'm sure Spencer and I can do another engine pull party
mattw
Engine is out..
I decided to modify the radiator core support so that I could unbolt the center section and remove the radiator to pull the engine out forward. This allowed me to NOT disconnect my tranny and power steering cooler lines.. It also allowed me to leave most of the core support in place while the engine gets pulled. Plus I was able to leave the hood on..
My little helper helped me mark areas to grind/weld:
Center section removed:
Radiator with top section of support:
My son raising the engine:
And its out:
So I was looking everything over very carefully looking for: things rubbing, things melting, etc... The ONLY problem I found is that the top of the core support was rubbing my radiator:
I also hit the side tank of the rad with the sawz-all when I was cutting the core support and put a tiny hole in it. So I am going to have all of this welded up.. I'm scared to try to weld alum that thin myself.. I already fixed the back of the core support so that it won't rub anymore..
