Boostedpimp said:looks great man.. damn I think you may have passed Ed Hess in having the most an lines![]()
ViciousV6 said:He still got me beat with the Sheet metal intake. I won't be going there. Yea we might have close to the same weight in An lines on our trucks.
Ralph
ViciousV6
Don W. said:DAQ: Where do I get that TB connector? I want to use it to do a vac (as is pressurized leak) test without the upper IC in place
Boostedpimp said:You talking about the silicone coupler? I believe it's a 3 to 4" coupler at least it is on my truck
wouldn't that depend on the alloy used?Tommyquest said:Is that tank aluminum? If it is the alcohol will corrode it, cake up, and clog the filters, jets, and potentially burn out your pump.
It might last a little longer if he doesnt use 100% methanol like maybe 50/50 water. You should do a ss one before long . Either way it all looks great .MikeRenz said:wouldn't that depend on the alloy used?
MRKING said:It might last a little longer if he doesnt use 100% methanol like maybe 50/50 water. You should do a ss one before long . Either way it all looks great .
MRKING said:Ralph was it a pita to convert to ss on your vacuum lines ? Been thinking hard lines or ss soon on mine . What -an size did you use
Tom you adding more mods , I noticed the unhooked oil lines and no pwr str pulley .
