Ok here is the deal...i understand this a bit.
let me get this straight: half of the memcal is an eprom and the other is the ESC. When piggbacking a chip, the ECM will be using the eprom from the new memcal but uses the ESC that is still on the stock memcal correct?
right or wrong, i get a code 43 and even without a code, my "knock count" on datamaster is cycling over and over and over again. That is at idle, yet spark retard is 0 degrees.
I thought it was perhaps how i installed it, but now that you said what you did Mike, it has to be right. If not, I even tried the wrong way (there are only two ways) and I still get the same thing.
Is there a way you can fry the ESC or mess it up? All I have done was remove an ultimate chip (it ran great) and replaced it with a Dig chip (he isn't going to get the eprom wrong) and i'm having this trouble.
Is the ESC module shot? I'm assuming it would run bad if so, but what causes that and if it uses the ESC module on the stock chip, whats the problem when I used it with the ultimate? Can't put that back in as its sold.
I am starting to think the ECM is fried?
I have no idea what to do???
