Piston Damage
Syclone #1188
Got the motor pulled and disassembled. This is what I found :shocked!: I got lucky there was no damage to the cylinder wall, going back stock bore with some forged pistons.
[/URL][/IMG]
atkonkler
Is this your bush?
Re: Piston Damage
What were the symptoms of this if you don't mind sharing. ..or did it just go kaboom?
Syclone #1188
Re: Piston Damage
It was detonation that did it. It started shifting harder at part throtle, Had very little vacume with alot of blow-by out the valve cover. Did a compression test, it had about 50Ibs
Static
Re: Piston Damage
Im afraid this is what mine will look like when I get my block out this fall. Ran out of time to do it over the winter. That and theres a Mopar 408 build occupying my engine stand currently
