pistons/rods help
kessler
i need to know what the specs are for a set of Pistons and rods if i go a .30 over bore and what the length of the rod i need. This is all for a stock stroke
Example
LENGTH-5.7
ROD JOURNAL 2.1000
PIN DIAMETER 0.927
WEIGHT 635G
kwick6
Re: pistons/rods help
SRP Piston spec:
SRP 4.030 forged pistons / Pin Diameter 0.927" / 492 gram weight
Eagle H beam rod:
2.250 crank pin / .927" piston pin / 5.700" length / 665 gram weight
93ty475
hmmm....here's something more for you....I snapped a photo of it before I threw it away last week....specs on JE extreme duty.030...I have photos of the rest of the other two pages if you need....
kessler
What do you want for the rods????
Also i noticed the the rod length is 5.7, But is it Possible to throw in the 6.0 in there with out changing anything else or whats the Diff. And would it even help? Sorry ive been out of the game of V8s for so long that im having a Brain fart.
canadian
sy in progress
A 6" rod isn't recommended simply because you don't get enough meat in the piston area when you have to move the wrist pin up. Asking $350 + shipping for the rods.
ghettosled
SYTY SUPERSTORE
well to start a 6" rod with a 2.25" journal size isnt a common rod, plus you would need custom pistons to locate the ring lands where they need to be for forced induction. Can be done, granted your deck height is where is needs to be, but save the hassles and go with readily available parts that have been proven.
