Pitbull Chip
TYTILIDIE
METH HEAD
Im sure this topic has been beat to death but Im asking again if it has. What are the characteristics ofthis chip? What is it programmed to do i.e. ? I know a guy here in town who said I can have it as it sucked in his truck. He is pretty well modded though so I thought I would give it a shot. I was going to go for the Ultimate finally but when I claled to order it I was too late and was told there is one more batch and all are spoken for...the Ultimate is discontinued. This really sucks but want to know what to expect from the pitbull as it is free. I decided to take my $ for the Ultimate and dump it into External and EBC from JER. If nayone has any input onthis Ild like to know. Thanks in advacne..
Mike
InvisiBill
Re: Pitbull Chip
The Pitbull is still a 2 bar chip, like stock. That means it simply can't see anything over 14.7psi. 15psi and 25psi look exactly the same to the chip (that applies to ATR, stock, Hypertech, and any other 2 bar chips). There is no way to adjust fueling for 16-18-20-25psi, since it can't properly read any of those.
The Pitbull uses open loop boost control. It just tells your wastegate to go to __% DC. You adjust the wastegate arm to get that __% to match up with your desired boost. It was made with about 16psi in mind if I remember correctly. Like I said, it can't properly read 16psi though, so it's just coded to run a little richer. Other than that, it has some minor tweaks, like limits and turnon temps and stuff. It's generally regarded as one of the better 2 bar chips, but it is still a 2 bar chip that's fairly close to stock (referring to the 137 version).
http://www.syty.org/old/promguide.html has some info on the Pitbulls and other chips.
If you really want something good, get a 3 bar chip from one of the other chip guys here. There are several who are highly recommended. I think some have generic chips similar to the Ultimate (should work pretty well on most trucks with a certain build), or you can have one custom made via your datalogs.
