TYTILIDIE
METH HEAD
This post will be for all of us new tuners. I recently aquired all of the equipment to start tuning with and found that just getting set up was more complicated than tuning itself. I had help from a select few and was stumped even then. Its hard for experienced computer guys to help us out with such basic steps sometimes so I thought I would try to simplify the equation so that newbie tuners can get started with ease.
Please try to keep in mind, that not everyone is tuning with the same equipment and I DO NOT have all pieces of equipment accounted for. I went with a commonly used set up and will try to provide the best instructions for it. Perhaps as we go along, people with experience in other types of equipment can post thier info and we can incorporate it in here.
This post will go through some changes as experienced tuners will give thier :2cents: and things will be changed accordingly. My hopes are for this information to be sent to the VAULT so that new tuners can find everything they need in one place. Or when someone asks a question about it, people can link one link instead of 10. So all I ask for now is please noone reply in this thread. If you have questions, criticism, info to add, or comments, please PM me for now until I get everything organized and correct. Thank you.
Abbreviations and "LINGO"
>="enter" or "go to"
/="or"
I have decided to include the following pieces of equipment:
1. Tuner Pro RT- http://www.tunerpro.net/download/SetupTunerProRT_v414.exe
2. Datamaster- http://www.ttspowersystems.com/software/dm350/TT/setup-TT.exe
3. Ostrich- http://www.moates.net/product_info.php?cPath=50&products_id=57
4. Innovative LC-1 and XD-16 Wideband o2- http://www.innovatemotorsports.com/xcart/customer/product.php?productid=16164&cat=262&page=1
5. ALDL Cable- Contact PPI TYPHOON here on the board for one.
6. GP1 package- http://www.moates.net/product_info.php?cPath=25_36&products_id=41
This is all the equipment you will need to order. Somethings are preference like the XD-16 whcih is just a gauge for the LC-1 so that you dont always have to pop open your laptop to know what your A/FR is. The GP1 package is not necassary but is nice cause you get the two chips with just incase you decided to to some chip burning in the future.
TUNER PRO RT
First go to the link and then download Tuner Pro RT. Dont forget to donate the $35 for registration. Once you get Tuner Pro loaded into your laptop ( I burned mine to a CD ), go to http://www.nwstp.com/forum/P4_section_9.asp
and download http://www.nwstp.com/files/paul/58_2&3Bar_Beta_0.9.1.zip and http://www.nwstp.com/files/paul/1227749_2&3bar_58_rev6a.zip. They are located under: Tuner Pro files on the left hand side under the NWSTP NAVIGATION bar.
These two files, are your ADS and your XDF files. You will be saving them in your XDF file.
The XDF file, is what Tuner Pro uses to define our ECM communication against whatever BIN we decide to use. The ADS is: ALDL DATA STREAM definitions. This is what Tuner Pro uses to commuincate through the ALDL port.
Once you've gotten to this point and everything is loaded successfully into Tuner Pro RT, you then will need to find yourself a BIN. The BIN is the program you will load into your Ostrich. I personaly used the Moates starter BIN. You can simply post in the CHIPPING section asking for one and you will more than likely get one. Ild like to try and get a seperate VAULTED thread or maybe even a section on SYTY.NET that has all of the XDF, ADS and BINs posted on them. Not sure what that would entail but it would be nice to have everything here. Once you have a BIN and have it loaded to Tuner Pro, you should be able to open it. At the top of Tuner Pro you should see: "Tuner Pro RT - YOURBIN.bin l XDF File - NEWXDF.xdf" . YOURBIN is the BIN you downloaded and NEWXDF is the XDF you loaded. To see your tables, click the "Show/Hide Item Lists" button. This button is located to the lower right of the Help button. It has a little arrow facing left.
If you want to datalog with Tuner Pro, you will need to plug your ALDL interface into your laptop and then into your ALDL port. You then want to click on the D (dash) button on Tuner Pro. There is another button that has and arrow facing left and an arrow facing right, this is the button you hit to actually connect to the ECM and start logging data. When it comes to WBo2 and the Ostrich we will come back to Tuner Pro. This is meant to just get it set up for usage.
DATAMASTER
Go to TTSpowersystems.com and download the Datamaster program for the Syclone/Typhoon. Registration is $100 last time I paid for it. You can use the free version and you only get 20 runs. Install it on to your laptop. Datamster is very easy to work with. However, it is ONLY a DATALOGGER. You can NOT change perameters with it. Basically you plug in your ALDL cable. Then you open Datamster, go to FILE>Record ALDL Data>FILE>OPEN...>type name of the run you are going to do>OPEN and then a screen will pop up. It will say "Serial Data Acquisition bnm.uni" at the top. You will then push start to record your data. You have to select the right COM port by going to SETUP>Comport and then select which COM port your are going to use. Most people use COM 1. You shouldnt have to do much more from there.
LC-1/XD-16(gauge) Installation and Purchase
You have a few options here. I am going to go ahead and explain the way I did mine since I feel its the best way and makes the most sense, even though it does cost more. First off, you dont have to get the LC-1 but it seems to be in common use so that is why I chose it. Plus Jeff recommended it. You also dont have to buy it from Innovative. I got my LC-1 and the XD-16 from JEGS for the same price as everywhere esle. The LC-1 alone is $199 and with the XD-16 it costs $399. I know that $200 is a lot for a gauge but it really is nice to always be able to see what your A/FR is at all times. Now i have heard some bad things about the LM-1. I hear you jsut shouldnt buy them anymore. Thats all I will say about that. I have no experience myself however.
So, purchase your LC-1 and hopefully XD-16. When you get it, it will seem utterly confusing. If you are going to run it with your stock narrow band, you will have to have to the bung included welded into your Downpipe. If this is the route you decide to take you should be able to just follow the instructions included and be ok. If you decide you want to run it in place of the stock o2, it gets kind of confusing.
First, you will need to get some ECM connectors. I got the flat spade connectors from Autzone which worked OK but then decided to get some authentic GM connectors. They were free since I have someone on the inside
I simply took one out of the harness and matched it up. Youre going to want to drop your ECM or if you have it in the glove box, un hook it and pull your wiring harness out of the glove box. then you will locate the PINs.
SKIP SKIP-WILL COME BACK TO THIS
Now that you have your Wide band hooked up, you have to calibrate it. This can also be confusing but not that bad really. First things first, go to LOGWORKS then to LMProgrammer. Once you have that open, click on Analog 1, you have to make it look like this:
After that, open Analog 2 and make it look the smae:
Now I dont know why but, I had typed in 20.00 and for whatever reason it goes to 19.99 or 20.01 but when I open it back up its as I typed it in. Once you have this part done, all you need to do is CAL the WB. On the XD-16, I push hte CAL button 3 times and IM done.
Now you should be able to read your WBo2's data in the AFR target box in Datamaster----will post a pic-------
Under construction...........will continue later..........If anyone has anything to say at this point, PLEASE PM me and dont reply. I dont claim to know everything so I may do something backwards or leave something out.......This could take me a while too BTW.............Thanks everyone.
Mike
>="enter" or "go to"
/="or"
TUNER PRO RT
DATAMASTER
Mike
