Re: Please Help Code 31 Turbo Wastegate Overboost
mass427 said:
I own a 1993 Ty #0936. I pulled a code 31 out of my truck. I can't floor my truck without this problem happening. I bypassed the wastegate control valve and the problem went away, but I didn't reach full boost. I replaced the wastegate control valve and the problem came back. I had a new 3 bar map sensor, so I replaced the map sensor and the overboost problem went away but it detonated very bad. Please Help !!! What am I doing wrong ?
What do I need to do ? The truck has 55,000 miles, stock with the exception of an 3 " exhaust. I've recently done a full tune up ( plugs,wires,cap & rotor). Also the egr valve has been recently replaced.
As was stated, the chip has to be calibrated for the MAP sensor. If you put a 3 bar MAP in, the chip would only see your 15psi as 10psi or something (less than actual), and thus would only fuel for that much boost. However, since the chip was seeing less than actual boost, it never saw high enough to set the overboost code. The 3 bar map sensor didn't fix the overboost problem, it just made the ECM not see it right.
When you disconnect the boost control solenoid, the ECM doesn't modify the boost signal to the wastegate. You get base boost.
How much of your exhaust is 3"? If you have a high flow cat, that could be the cause of it. The stock wastegate sucks. If you switch to a higher-flowing exhaust, the turbo faces less backpressure which makes the crappy wastegate even less effective. The only way to fix that is to replace the exhaust restrictions, open up the stock wastegate (see JS's custom downpipe for opening up the turbo service port), or get an external wastegate that can properly handle our turbo. If you get an external with the same base boost as the stock wastegate, you can simply tack the stocker shut and run the vacuum lines to the external instead. You wouldn't need an external controller or anything else.
