Please help identify these parts I found in my TY
ABOSS
I found these parts and have no clue what they are
#1 was a set cables that ran from the fuse block to the center console
pic link
# a switch that had no cables going to it, it was in line on the vacume line to the HKS blow off valve before the check valve
pic of switch
and the last image is of the alky kit :tdown: :rant: or what the last owner left in it has no tank but there was a pump with a hose to a nozzle that is in before the Blow of valve. what do i need to get it to work.
pic of kit
QUICK STORM
B.A.M.F. BMW Tech
Re: Please help identify these parts I found in my TY
all of that looks to be some sort of diy alky setup based on boost
Flyin Ryan
hated cuz he drives fords
I agree.. that one thing looks like a pressure switch for the kit possibly but the pics are really small.
ABOSS
so should i hook it up, if so, should i get a controller like i see in the kits they sell.
ABOSS
what do the kits have 2 tank kit pic
does any one have the instruction for install and how can i tell the size of the nozzle?
Flyin Ryan
That's a progressive kit.. yours looks like a kit that's ran off a pressure switch so there slightly different. I believe one tank is used to hold the meth and replaces your factory over flow tank and the second little tank is for the over flow to be mounted else where.
R1crashtets
I have a set of instructions for a kit just like that if you want me to E-mail them to you.
