YOUR intake air temps (IAT) are 103* F
YOUR Colant temp is 200* F
The knock doesn't come in untill you start letting off the thottle 1-2 frames.
The O2's are crashing about the same time your knock is coming in.
Check for loose brackets or anything that could vibrate and hit the block/manifold. Are you running stock boost levels with a 2 bar map or do you have a 3 bar map. If so, did you set the settings to accept the 3 bar map?
I looked @ your other two file you sent...
Why are you having dtc errors # 43 ESC fail?
Take it easy on the truck till you figuer it out! OK.
Find out whats causing code # 43
