Bill Z
I need some technical advice. and may some wording.
What do you call the throttle butterflies in the plenum on my Typhoon. I
think my off idle baugh (hessitation) is because the stop on the plenum was messed with.
The little seal that seals the adjustment screw had been removed. I was
told that the TPS was suppose to be .5 volts and I couldn't get it there.
The stock TPS isn't adjustable, so I used my Dremal tool and made it
adjustable.
OK. I figure the stop is out of specs, the TPS isn't in sync with the throttle so
the air fuel mixture at idle is all screwed up. So, I get the 'off idle
hessitation'. Sounds right?
How do I get it right? How do I set the butterflyes (or what ever they
call it) back to specs? Then I can set the TPS back to .5 volts. Then, maybe, things
will start running right.
Where do I look?
Any real good suggestions?
adjustable.
Where do I look?
