Plug gap
I just ran a test of plug gaps. I was getting a slight miss at WOT so pulled the plugs and re-gaped them to .026 and the miss got much worse at high (15-18+) boost. Back to the garage, pull the plugs and found 2 with cracked insulators. Now there is no way that I can tell if I cracked them on the install or the removal but I replaced them, re-gaping them all back to a slightly loose .036. Went for a test run and based on my little test track performance the truck is running better then ever.
So, point being, I'm not, at this point in time, convinced that 20+# of boost and meth requires a narrow gap.
If we race Wed (possibility of some light rain) I'll know for sure but the truck felt real strong and Data Master said my 1/4 was under 12, we'll see.
BoostedSUV
Re: Plug gap
interesting... I had mine gapped at .035 and truck felt like it was on a rev limiter at 4500. Wouldn't go past 13psi and was surging like crazy. I tightened the gap up to .025 and it went right to 18psi and truck pulled like crazy! Like being in a different truck. Interesting how different trucks act with different gaps...
