Plug reading gurus step inside.
the baPhoon
Doing some preventative maint. on my ty before i fire it up after a fuel pump and thorough fuel system clean. Changing plugs reguardless.
What do you guys think about this? Truck did have a little knock and would read rich occasionally. In the 10.8 range on my dm100.
All the plugs have <4000 miles on them.
Opinions welcome.
MadMike
Re: Plug reading gurus step inside.
Looks like you need some better pics. a closer one like the last pic and one from the top closer should do it.
You're looking for two lines on the electrode and the fueling ring on the porceline.
Kinda see the one on the electrode where it goes from tan to metal/brown. My guess is a little heavy on the overall timing but my skills at this are super limited at best.
'They' like to have a nice clean set do a pull, shut it down, then pull them to really do a read.:2cents:
BMFB
Not to scale
it *looks* like your timing is a bit too agressive and your not getting a very good spark. a closer pic of the ground strap woudl help.
also, it doesn't look like the gap was set right and the threads look kinda weird being so clean. Its running real rich wot.
MIXEDBREED
+1 to properly read spark plugs you have to shut the vehicle off after the run. That means dont drive it back to the pits if your at a track you would have to tow it back to you parking spot, pull the plugs, then you really need a spark plug reading tool which is 10x mag to get a good read and see down in there good for any signs of detonation, check the fuel ring, the timing and heat range, but if you are gonna do it then you might as well do it the right way- right.
If you idle the vehicle or cruz around after a pull you will get false information when you try to read the plugs.
the baPhoon
Not trying to get THAT in depth yet.
Just some simple reads like the timing idea stated twice. Looking for suggestions while its down.
Once its up and running again i can do a small run to look more in depth.
Ill snap a few better photos this evening.
Like i said, not trying to tune atm just looking for opinions on things that may be obvious to you guys that i might have overlooked.
MIXEDBREED
Well then just check the ground strap and you can shine a small light on the plug and look for small diamond like reflections ( metal from pistons ) and look for black specs which are mostly from detonation. Those or some good quick easy checks.
qbnkiller
Conflaguration Specialist
Take a better pic of the top one and post it here.
Change one of the plugs, go drive it a bit to get some heat in the plug, make a good hit and shut it off quickly. Swap that plug out with a fresh one, drive home, and post pics of that plug.
the baPhoon
Looks like i need to pull some timing. Set it at absolute zero TDC.
Just got dm loaded up on my laptop. Soon as i get her runin ill make a few logs.
RE timing, seems one is never done here but my truck seems to like -2*. I guess what I'm saying is that IMHO timing should not be set in stone.:2cents:
qbnkiller
^^^timing is never set in stone. Be "the engine whisperer" and do what it tell you.
That plug has too much crap on it to make any kind of recommendation off of it.
