plugs and wires
Gnocide
turbo game burt reynolds
its time to tune
my ngks are breaking up under boost
so any suggestions on forum vendors or just advance auto?
Gnocide
Re: plugs and wires
thanks
i got to ask about #6 though
i have an atr down pipe and that means a 90 deg boot resting against the pipe that usually has to be made
most wires dont 90 #6
Damian
Re: plugs and wires
ACDelco wires and UR5 plugs with a fairly stock engine or UR6 plugs for higher boost. Works great for my big turbo.
Re: plugs and wires
I recently helped a peep install a set of Hood's wires on a stock truck. Every one of them other than #1 (the longest in the set) was at least 6" too long. No matter what we tried, it looked like ass. A couple of them were so long we put a 180 loop in them behind the distributor.
Maybe we got a set with the wrong lengths, or for the wrong application. I don't know. But we were un-impressed with the fit considering these engines are pretty much the same, and the routing doesn't change, so the fit should have been about perfect. Not all over the place trying to use up extra length.
5 of the 6 were way too long.
Interesting. I've dealt with Hood a few times over the years. Except for one recent, and rapidly taken care of, issue I've never had a problem. But I've never bought wires from him either.
The Magnacor set that I have, were a bit long but nothing like you mention. Maybe an inch or 2 depending the cylinder. #6 factory looks like a 45*, #1 is straight, the rest are 90*. I'd make #1 a 45*, no need, IMHO, for a straight there.
I have a boot on #6 and 2&4 wires (not the ends) in a boot tucked between the dip-stick tube and head. Seems to work well and keeps them off the DP. (Head temp nothing close to DP temp.)
Sportmachines
Re: plugs and wires
Check out our wires. Made by ICE Ignition, 9mm. Made to the original wire lengths and boot angles.
Gnocide
Re: plugs and wires
as far as angles go
i need a 90 for the atr downpipe on #6
the quick solution would be a set of v8 350 wires -they are all 90s on both ends
they are also cheaper than the v6 set and readily available anywhere
