PLX R500 Wideband O2 Sensor
SBNova
Re: PLX R500 Wideband O2 Sensor
It doesnt compare to datamaster, or any scan software. Its almost like comparing apples to oranges.
Datamaster, like most scan software, is run on a laptop and scans the ALDL datastream so you can "read" all the data that the ECM is seeing and computing. You can view data from all the engines sensors, timing, fueling, ect, and see how the ECM is responding to that input.
A wide band, like the PLX you've shown, is a very specific tool centered around reading the actual air/fuel ratio. The factory setup reads the air/fuel ratio, but not anywhere near as accurate as a wide band, and the factory O2 sensor is only accurate near stoich or 14.7:1, where most wide bands read from roughly 10:1 all the way to 20:1. A wide band is a great tuning tool for a performance engine, and even more valuable on a turbo or SC engine where going lean could cost an engine. The PLX you found also seems to have other input channels to simultaneously monitor other engine parameters- which is important to compare the WB reading to. Most WB's can log other data but you will need to wire the unit to your sensors somehow.
I have a wide band, and its great. I also use TunerPro RT for scanning. One or the other is fine and will help tremendously, the two together are awesome. If I had to choose only one, I would go with a scan program over a wide band. Some scan software is free, and TunerPro RT has a $30 donation if you like using it so its pretty cheap. You'll need a cable and a laptop to run it though.
I hope this helps.
