Poly Motor Mount Questions
mrweelr
I'm putting ATR headers on my truck within the next month along with a bunch of other stuff. I want to put those heavy duty poly motor mounts in my truck while I'm in there. Can the mounts be changed with the motor in the truck? I'm thinking it won't be too bad with the stock exhaust manifolds, turbo, and DP removed. Will the engine lift enough to allow clearance for removal/installation of the mounts? Anyone who's done this, please advise.
Thanks
ParTyBoy
To answer your question... Yes, they can be installed with the motor still in the truck... If you ask anyone who has done it... like Jeff Scott... your answer will be.. Yes, but it's a bish.... Speak with jeff about purchasing his mount kit.. and here's his install page..
http://www.nwstp.com/jeff/mountstech.htm
mrweelr
Hmm...no one else has had the balls or stupidity to tackle this job? Guess I like punishment, he he. I just want my motor to sit still without using tie-downs that keep stretching. Rest assured, I will post here after I get them installed.
