Re: Poly motor mounts 4.3L
OK - I was nervous too about vibration etc etc.
It's not that big of a deal - I can't really notice - you certainly don't get a bone ratling sensation. To be honest, I wouldn't be surprised if people got it wrong sitting in my truck and I asked them if it were solids/rubber.
One thing - DO NOT GET SOLID MOUNTS FOR YOUR TRANS IF YOU GET SOLIDS FOR THE ENGINE.
You need some give in the system. Your frame bends etc etc. That's what RPM recommend, that's what I did.
Sharkbait is saying otherwise but in my experience you need the poly Energy Suspension tranny mount. Do a search.
Trust me, doing the motor mounts is a PAIN IN THE ****ING ASS. Do a search. Do it once. :tup:
There is a mod on here you can do with a welder and a drill if you have the skills - very easy it looks like. Makes installing and removing the frame pads a breeze I think. Again, search!
I spent around 8 hours getting the mounts on/engine in. But now I will never worry about the melting or the engine breaking loose and destroying the radiator shroud etc etc (assuming the bolts are tighter than my calipers :rotf
Note that it wouold have taken that long with stock pads as well...
Seriously,heat shrouds around the mounts? You're asking for drama....
Good luck with whatever you decide...
