Lynn D. Brown
Installed my Poly Mounts a month ago w the stock mount bolts, still finishing engine install.
Looked up from the bottom, I noticed that the stock mount bolts R too long for the Poly Mounts, which I guess must be more narrow. So, I had to buy some Grade 8, 4"- 7/16" Coarse bolts. But they have no points on them, which U need because U have to pound in the bolts. So, I had to find a grinder so that I could grind a point on the bolts.
Did everyone else w the Poly Mounts have to get shorter bolts and grind a pointed, slanted surface on these bolts ?
