Pontiac 23* intake installed
Windedv6
Ty n 10s
Just finished my Pontiac 23* intake install.....some pics. 8) More to come as it's now in the ty and running.... :D
John
Windedv6
Ty n 10s
I take it you will be at the park on Sunday....if the weather holds I sould be there. I am scheduled to be at Milan Friday nite and Saturday for some tuning with David Henninger (fromerly of Wheel to Wheel) now owner of Hard Core Motorsports, to do a tunning session with the new Big Stuff III box. Looks as if I will be making a weekend out of Detroit. Keep the weather in check!!
John
93 TY 2185
John
Yes, I will be at the park Sunday. 8)
If it looks dry I may be at Milan on Friday. :wink:
I still have your cell# from last year I'll give you a call latter.
If it has change PM me with your new number.
Typhoon #1133
nice set up John. looks really sweet. June 30 i am planning on going to Muncie dragway if you would like to show up. Nothing like 2 white Ty's racing together. Mabey they will get them mixed up and think i am the fast one.
later,
Keith
0966Sy
Code what?
Wow, Is that going to clear the hood? So that intake bolts up to the vortecs with no modifications. What kind of gains are you expecting out of this project? By the way sweet truck and killer video with the 311 song 8)
Windedv6
Ty n 10s
The heads flow 274 @ .500 and 282 @ .600 according to Flow Tech. I am running the 412 Comp which is .500. They said that there is more to take, but for street/strip use and to have the the reliability for put miles on them(as if I put on a lot of miles :roll: ), this is were they wanted to stop.
The intake is not any taller and will fit under a stock hood. The picture of the stocker and the Pontiac intake setting on the bench shows different heights. This is because the stocker sits flat, whereas the Pontiac has a valley that drops into the lifter valley of the engine. This separates the floor of the intake from the runners.
From the front engine rail to the top of the TB there is little difference in height from the stocker.
I don't know how much this will help. I have to believe that the mare fact of equal air distribution should be of some improvement. I do a lot of plug tuning and our stock intake has a lot to do with the fact that our cylinders get loaded differently, thus some are richer/leaner than others. This doesn't show up as much on stock and low build motors, but on high air flow requirements you start noticing sufficant differences form cylinder to cylinder. Since our O2 sensor only samples an average, we typically tune our afr to that average. We would be amazed at the differences in each cylinder if we could do an o2 for each cylinder.
I can tell from plug reading that some are lean and some are rich. In those cases there is power loss....but the single O2 test says that the afr is right on.....
This type of an intake should load the cylinder equally especially at high air flow. So far I can tell you this....the FAST program is wanting 6-8% more fuel correction at wide open throttle @ 20 boost. I expect that it will be as great of a change or more as I tune it with higher boost.
For those that are curious....
I kept the same injectors which are 75#s (have 84s if needed later) and used the same program that I ran some 11.2s on at the track a week before changing the intake (75 degree and low humidity weather). My interest in this is to see what kind of changes to the program this intake would cause at WOT. Drivibility isn't comparable as the ford TB is a mono blade an allows a lot more air at the same TBS value as the twin 58mm previously on the syty intake. There was alot of table changes made for drivability.
The twin 58mm throttle body is rated @ 1,000 cfm and the ford 75mm is rated at 980 cfm so at WOT any differences in fuel needs should attributed to flow. The increase in fuel needs probably confirms what we all know....that there is a bottle neck in our stock intake that restricts at high flow. Another noticable difference is that the turbo spools much faster, even when that extra fuel was tuned back in.
Like it so far....alot. :)
John
Windedv6
Ty n 10s
SyTyJedi said:
Does this manifold fit the vortec heads without any modification?
It fits the vortecs if the vortecs are set up similar to mounting the stock intake. You do not have to weld the intake, but the hole alignment change in the heads is needed. One difference between the stocker and the Pontiac is that there are two holes stagered between the runners and the Pontiac only hole centered.
You can see the hole pattern at the bottom of the intake....
John
