Re: pontiac help
Fully ported Pontiacs imo .
Either set will be expensive to get road ready . As far as specs etc , its all been covered pretty well over the past 10 years , sometimes you have to just keep digging .
If you cant find what they need to work properly at the hp level they can put you at , they may not be needed in your build . Unless you have a strong low 10 sec truck being built , other heads can get you where youd like to be .
What are you trucks goals ?
