pop-pop//foul one plug.....
chadjett
one night i was drinking and let the wrong person drive the sy.
he held it to the floor it popped real loud he didn't let up and it done it again this was around 100-120 mph. now it fouls the same plug over and over sometimes in a month sometimes in a week!!!
what is the prob and the fix??
its very drivable no knocks or anything just fouling plug and smokes sometimes not as much power though.
going to build an engine this yaer or next if it can get me buy this year for weekend cruises no biggy
but i am going to be buying a lot of add-ons this spring will my give out pretty easy with the added power
G
Guest
Guest
well, sounds like you have major problems. could be a broken ring. i don't think the pistons can hit the valves but i might be wrong. any of you tech guys chime in on this one. if you have a power loss it is either a ring-piston problem or the valves. take a compression test wet and dry and post your readings.
manitoufs
Forget the add-ons. Your buddy broke it. Start saving for a teardown. And if you don't treat the engine with more respect, you may as well start saving for a major rebuild.
turbojimmy
Sounds like you might have a hole in the piston in that cylinder. A buddy of mine had a GTO that was the same way. It had burned a hole in the side of the piston. Plug was oil fouling, and it was smoking. The thing was that you'd think it would be smoking really bad, but it really only smoked when he got on it. I was surprised to see a hole in the piston - the car really didn't act that sick.
Bottom line is you've got big probs - sorry. Time to beat the crap out of your "freind" for being an idiot.
Jim
chadjett
i don't really need to tear it down right now it still runs pretty descent except for fouling the plug
i just didn't know if you could pull the head and the oi pan and cet that piston and rod out of that cylinder. iknow its not the best thing to do but if it would fix the plug fouing thats all i need for now.
i probably won't have the money for a rebuild this year but i will have money for odds and ends(ultimate,walbro,etc,etc....)if i do a rebuild i want it to be a 500-600 hp engine which means $$$$$
he isn't my friend just a hang around that is a dick sometimes probably done it on purpose because i was polluted i should have beat the shit out of him
i just wanted to find out what could be wrong and the easiest fix
my money is going on the body this year. i want to build an engine on the side while can still drive it but don't like the plug fouling and the smoke
thanks for any replies!!!!
sometime in march i'm going toneed a set stock wheels, full set of cladding, harwood 4in. cowl
if anybody is selling this stuff then just email me
Another case of alky costing money....
I have to agree, sounds like broken ring to me....
And also another case of I want everything, but don't have or want to pay for it....
Time for motor, atleast from the text description.
G
Guest
Guest
best thing to do is park it! if it is a broken ring or a hole in the ring lands this will score the cylinder wall and just end up doing more damage. go buy a beater and start tearing the motor out.
chadjett
i wasnt asking for charity you are way to quick to judge... you figured that out about me by reading this post? you must be psycic!!! (not) it was a post to find out what was wrong with the truck not about money... and for sure not to slam me... do you get off by being shitty to people for no reason.... lighten up
Sorry to jump there.
If you knew me, you would have a whole different idea....
Text just doesn't do it most of the time...
The alky has a nerve in me, 13yrs old, hit head on, not fun.... I have a hard time feeling bad for anybody that experiences trouble because of alky.
I am from Seattle, and was a big part of NWSTP when I lived there...
Since I don't really want to be in Indiana, it is one of the ways I still hold on to the Northwest.... hence NWSTP Eastside
Southern Indiana, 7 miles from Louisville
Ian Turgeon
Cascading Inspiration
Pull the oil filler cap while its running and see if it puffs smoke, or if it puffs air (put hand over).
Richard Le
I pulled my oil filler cap while my truck was running and it wasn't puffing out smoke or air. Yet, I am fouling all six plugs in a short period of time. My truck doesn't smoke at all. What's up with that?
Tydriver
TurboLS6 Powa'
What is the source of fouling ? Is it OIL residue ?
Is it fuel ?
Rust stains ?
What ?
Need to know what the symptoms are, its possible that it maybe simple problem or it may dictate a full blown rebuild. These engines are notorious for shoddy valve seals, while its hard to believe it IS possible that it maybe completely toast and that maybe the source (if its oil) if not it maybe the rings as others have mentioned.. It maybe an injector gone haywire if its FUEL fouling.... The possibilities are almost endless.. Need more information..
Does the truck smoke at all?
Only on start up ?
All the time ?
Tydriver
TurboLS6 Powa'
Hey just noticed, you are in Greensburg IN, isnt that just East of Indy ? Say 20-30 miles ?
Get in touch with me, we'll have to hook up sometime........
Richard Le
Hey 92Typhoon, all my plugs were covered with oil when I pulled them out. Valve stem seals and valve guides were recently replaced. Compression check turned out OK. The truck is still running fine, has a great idle, and has a lot of power. The truck doesn't smoke at all, not even at start up.
smeagol
Only 3 sources for oil.
1 - valve guides
2 - blow by past the rings (loss in compression)
3 - sucked in via crankcase ventilation etc
Did the oil on the plugs change from before to after the valve guides were replaced?
Tydriver
TurboLS6 Powa'
1 - valve guides
Couldnt agree with Brian more... Check to see if theres any oil in the intake path (manifold, TB, intercooler etc) if not it has to be rings or valve seals.
U can check both of them somewhat easily with the correct tools.
When you did the compression check did U use a leak down compression checker or a conventional one ???
I will assume you used a CONVENTIONAL version and explain the LEAK DOWN model.
A leak down comp checker uses compressed air and a set of simple gauges to check compression, you bring each Cylinder to TDC install the fitting that provides air to the cylinder, attatch the gauges and apply the air pressure.
It measures the difference between the amount applied VS how much the cylinder is sealing/leaking...
Heres where you can trouble shoot it..
When the air is applied to your engine listen to where the leaking air is going.
Take off an oil filler cap and listen to hear if the air sounds like its bleeding into the crank case then its the valve seals or rings...
If its bleeding into the exhaust then its the exhaust valves (yes stick your ear next to the tailpipe)
since we have turbos and IC and the like its gonna be hard to check the intake but its done the same way...
U can check to see if its the rings by taking a couple Ounces of engine oil and squirt it on top of the piston being checked and it will temporarily SEAL up the rings if its the problem (you will see an increase on the gauge readings)... But make sure you have all the oil out before re-starting the engine...
Tydriver
TurboLS6 Powa'
OOOOOOOOOps I forgot to put this in other post... Heres a link to make your own leakdown compression checker.
Snap-On sells them (not cheap but nice)
This works wonders, it is what the general aviation field uses to check the health of the piston powered engines !
Leakdown Compression Tester
Buy one here :
Leakdown Comp Checker
_________________
1970 GMC C10 Stepside
1989 Ford Thunderbird SC
1991 Jeep Wrangler Sahara Hardtop <-- For Sale
1992 GMC Typhoon #0488
<font size=-1>[ This Message was edited by: 92Typhoon on 2001-12-31 14:26 ]</font>
