ed hess
race or get outta the way
The tranny line at the top of the radiator was cut so i could install aa tee n the line for the temp gauge. I used rubber line that comes with a tranny cooler. !st the upper end of the rubber popped off after my 1st trip to the track this past summer. Double clamped it. I was lucky to be close to my buddys shop when it happend.
Last nite as i left my shop the rubber line popped off the other end which was only single clamped. I gotta change this to AN fittings and ss braided steel line Before this fails and i am not lucky to be where i can get a quick fix without damage to the trannny ( i wonder if i havent porked it allready from this).
Anyone know the thread size of the fitting for the tranny line at the top of the radiator? Do i need a standard flare fitting or an Inverted flare?
I assume the steel line thats oem is 1/4 OD? or is it 3/16 or 5/16 OD?
Ya know that red crap really makes a mess of your truck when this kinda thing happens. I drove 7 blocks before i knew it blew this time. Needed 5 quarts. stuck line back on and crawled back to shop
