Port matching turbo
Hu Ryde
I know what to do to the turbo side but what about the exhaust manifold? Should the split be sharpened to a point? Should anything be done to the down pipe?
Hu Ryde
Good point! Thanks for the info. What about the exit side of the turbo? Open it up to the DP size?
rarebit
probably would want to open up the turbo outlet a little. but not bigger then the dp inlet. you want small going into big. bigger into smaller is a restriction. smaller to bigger is not.
Hu Ryde
rarebit said:
a curve or arc on the split would help the airflow. sharp points usually generate turbulence and heat.
Not to say your wrong but what about an air plane wing? Does the front of the wing make the wind flow different at the back also?
ttdolson
Yes, that terminology would be correct if you were trying to generate lift...
With this application your looking for flow rate.
same to same = good
smaller to bigger = ok
bigger into smaller = not good
smeagol
I'd be careful sharpening that edge - any sharp edges can create stress risers, also has more surface area for heat to build up versus the amount of material at the edge. All this *can* lead towards cracking/destruction - metal material going through the turbo = BAD
just my $0.02
Hu Ryde
What about this little nub?
Here is the piece that I'm going to take the sharp edge off of in the center.
The black area at the bottom and sides is what will be removed to help increase flow.
For anyone who wanted to know or interested in what we are talking about.
