Porting my stock turbo
Hi all,
Here's my plan. No budget for 3" DP but I have a 3" high flow cat.
What I'm thinking is to port the stock turbo, install the cat and run 3" exhaust from there. I've seen lots of posts about porting the turbo, doing it "correctly" etc but no photos. Does anyone have photos of a stock ported turbo?
Thinking ahead can the porting be done to allow for removing the puck and a 3" DP later? Or should I just wait?
Hints? Comments on my plan?
Thanks,
Mephisto
These trucks are cursed
Re: Porting my stock turbo
nice work... where do you think the overall gains are from doing this? mostly on the top end?
Thanks much. Those photos seem to be concerned with porting the turbo inlet, which is cool. I was under the impression that it was the wastgate passage that needed to be ported. There are wastgate passage photos there but they seem to be unmodified. Does that passage get ported or does everyone just port the inlet from the manifold?
Thanks again.
Ian Turgeon
Cascading Inspiration
generally people send thier housings off to get the wastegate ported, as it requires a bit more then a grinder. I went with an external gate, so I didnt really care about the wastegate that much. Most of the gain, performance wise is in the mismatch on the exhaust inlet for the turbine housing, the wastegate mods you can do will generally help with boost control on free-er flowing exhausts.
I couldnt begin to tell you what the gains are... I went from running 14's with bad boost control (stock everything) to 13.0's with the ported turbo, external gate, and saudi resonator. Of course I also learned how to launch my low-stall converter by then as well, so who knows.
Haven't heard of sending it away. Do ya know where? Almost sounds like fuget it for now and save for 3" downpipe. Really appreciate the comments though.
jbone
jwaller does a 57mm upgrade for the stock turbo, and he also does porting. Im gonna have him do mine very shortly (hopefully) and js manufacturing is the only one to my knowledge that does a DP for the stock turbo setup. I think it was like $450 for full stainless 3" but check to make sure prices havent changed.
Ian Turgeon
Yea if your dead set on a mitsu exhaust housing, porting the wastegate port, installing a larger flapper and opening up the service port at the rear of the housing, all combined with a collector 3" downpipe, should take a mitsu housing about as far as it will go.
