Porting turbo, what tools do I need
Ian Turgeon
Cascading Inspiration
Gonna clean up the stock turbo and do some grinding on her.
Ive never done any porting work, so I need some advice.
Anyone have a good idea of where or what kits I should buy that would contain all the grinding/sanding/polishing bits I would need.
Can this be tackled with a dremel, or would air be the way to go?
I plan to tac the wg puck closed, bellmouth the inlet, match the exhaust inlet, and perhaps smooth out the edges on the exit. Is there anything else I should be looking at? Perhaps a way to smooth out the exit from the exhaust housing other then rounding down the edges.
I would use air grinder with a carbide bit and wd-40 to keep it frow galding. dont know as far as it goes with the polish though. the carbide will make short work of the ex housing :) . Just be sure to wear gogles and a long sleeve shirt to keep from getting burs on-in your skin and eyes. It hurts like a bitch and they are hard as hell to get out.
Ian, I have a decent handheld electric grinder you can borrow. It was strong enough to grind the ATR header flanges for thermostat clearance. If only I could retreive my tools from the ex :evil:
SY2932
Administrator
Carbide burrs in a grinder be it pneumatic or electric is the only way to go. A buddy of mine was porting his turbo with a grinding wheel (very slow) until I showed up with my standard bed of tools. Exchanged his grinding wheel for one of my carbide burrs and it was like a hot knife through butter... As mentioned above, make sure you wear long sleeves and safety goggles. The speed of material removal is impressive as is the pain that comes from the metal slivers it produces. And they go EVERYWHERE. I bought my set from the Eastwood Company: http://www.eastwoodco.com/ item number 46067 for $49.99. Any polishing can be done with the abrasive rolls that Standard Abrasives makes like in the kit Jesse mentioned (have one of those too, can never have too many tools :p ) HTH's
Mike Campbell
