Possible intake leak after turbo... Help?
MjP
Banned
A) Is that stupid plug thing on the throttle body a possibility (Part Number???)
B) Is there anywhere else on the throttle body that could be fucking me up?
C) Something I'm not aware of?
Thanks Guys
Falco
A) Do you mean the plugged vacuum port above your PCV connection? Check it with the bike tube method and spraying water...
B) It's usually leaking at the shaft ends quite an amount of air out. That's considered normal It can leak at a bunch of other places. Check it with the bike tube method. Possible places: at IAC, at the upper plate, at the upper plate's bolts, intake to TC gasket, lower vacuum port, PCV vacumm port.
C) How do you now, it's the TC leaking?
Later,
