power steering pulley
0966Sy
Code what?
I have some good factory ones, I can give you a part number for a newer one that has the spoked body that will allow you to remove the pump without removing the pulley. I have it wrote down, I'll dig it up later
syclone809
Re: power steering pulley
Newer style pulley 12605677, hit up eBay, I bought mine for less than $20, there is one on there now for $21
RealFastV6
@jb_and_his_coffee
Stock (Top middle - Powdercoated flat)
New style GM PN 12605677 (Bottom left)
March MCH-610 (Bottom right)
Sent from my iPhone using Tapatalk.
gringo76
you guys rock! I went to remove my pulley with a snap-on puller and it ripped the groove section that the puller slides onto right off. now I got to destroy the pulley to get it off and most likely the pump with it or at least the seal. my luck lol
RealFastV6
@jb_and_his_coffee
Yeah really need to pre-soak those fkrs to get them off in one piece, and even then still run a risk of tearing them up.
Damian
I always use antiseaze when re-installing them, always. Just when you hook up the tool, look at the "fingers", mine has 2 different sized ends. Not sure how the Snap On one is.
0966Sy
Code what?
I ran into this recently on my beater Jimmy, I used a pry bar to bend the pulley out to access the bolts. I then used a cut off wheel on a die grinder to get it off the pump shaft. Then warrantied the pump at auto-parts for a leaking seal.
