This is the Jegs order I placed and it may not be the best prices possible . Both of the mm steering adapters are o-ring , 1 goes in the power steering pump and the other goes in the steering box . I put the 45* in the box and the other 3 locations are 90* . The 45 looked close to how the line came from the pump and would work as a 90* if anyone wanted . The hose ends are not swivels so you must do one side and place/mark the other end . If you dont get it right , it will twist the hose and not fit properly when tightening .
0799640380 #6 5/8-18 F/P Power steering adapter $ 4.99
0799648050 #6-11/16-18 IF Power steering adapter $11.99
0799648060 -6x16mm P. Steering adapter $ 6.39
0799648080 -6 to 18mm x 1.5 O-ring $ 9.69
0799620411 #6 45* endura hose end $12.99
0799620421 #6 90* endura hose end $11.99 (x3)
0799632620 #6 Teflon pre-cut 10-feet $47.99
Besides that , you only need 3 feet of low pressure power steering return line from your local autoparts store and a 3/8 tee .I almost drew up a photoshop diagram for you , but I didnt know how many people read the crap I write and figured this was good enough. I know i had a lot of questions before that I couldnt get answers to , so I wanted to pay it forward and put this out there so hopefully it can help someone else .
